メインコンテンツにスキップ
Repair guides and support for drywall and plaster construction.
6回答 すべてを表示
Can you paint over intumescent paint with regular paint?
I have a steel beam in my new kitchen which I want to leave exposed. It already has been covered with intumescent paint. Can I paint over the intumescent paint for decorative purposes with regular paint? Or does it need to be some kind of intumescent paint? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@anna_asking this is a big depends answer. Intumescent paint is applied intumescent paint on the steel beam to protect it and obviously your building, work from the effects of fire. You would need to know the composition of it and then possibly contact the manufacturer of that particular paint. Some let you paint over it, others do not. Some of the better paint suppliers can also be helpful in determining if you can and may have a product available that would comply with this.
So, can you? Sure. Should you? Depends.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you I really appreciate your helpful response ! I will hopefully be able to find out the composition info.. thanks!
さんによる
コメントを追加
回答を追加する
anna_asking さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 67
今までの合計 2,019
