メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
Battery replacement odd behavior
Hello IFIXIT community,
I recently bought the MacBook Pro replacement battery kit that IFIXIT provides to their customers so they can do Apple’s job at a cheaper price. I was able to install the battery with no issues at all.
But, after a day, while using my computer after calibrating the battery for better results I decided to restart the laptop for some testing not related to its battery life. Before I rebooted, the machine life was at 69% but after turning it back on, the battery was showing me a 6% battery life which is super odd and insane at the same time.
If there is anyone that experienced this with their replacement and/or noticed but went away later after constantly using the machine, please let me know. I am an IT guy myself, but I do want to make sure I am not the only one that has seen this odd behavior on a computer.
I hope that somebody can share any thoughts and or a solution to this. In the meantime, I will disconnect the battery adapter and put it back in just to see if it is just a mistake I made.
Hope somebody answers soon. Cheers community!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
9 件のコメント
Please post a snapshot of CoconutBattery so we can see the batteries status iFixitでの質問に画像を追加する方法
さんによる
Hello Dan,
Thank you for commenting on my post. I have edited the content and the image should be now displayed. To me everything looks fine on the battery, also checked other battery apps while waiting for this response last night. Is there anything in mind that could be causing this?
さんによる
@danj Today while using two different battery use checkers or whatever you want to call them, I noticed that they provide different numbers from the battery's charge for example:
The mac battery shows 73% and so does the app "Battery Monitor". While coconut battery shows 67% and the mac battery shows 73%.
Do you have any idea why this could be?
Thank you
さんによる
@poporobright Coconut battery always shows a lower percentage except for when battery is fully charged.
さんによる
@arbaman - Correct! This is mostly do to the lag between the OS call to SMC from the app and its reply. Unlike the OS's native access to SMC.
さんによる
4件以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
The CoconutBattery output looks good!
Its what I would expect. How about cleaning the MagSafe connections in case your one-wire sense line was not making good contact. Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters. Make sure the cable is not damaged in any way, also make sure you have a real Apple charger! There are many fakes out there that will damage your system OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth.
See if after cleaning the connections and if needed a replacement charger fixes things.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Hey Dan,
Thanks for all the support. I got this mac charger from my tech company so I genuinely think it is a true mac charger. Also, I will clean the port and see if it keeps changing and or getting better while I continue to use it.
Will keep you posted .
Thank you
さんによる
@poporobright If the Mag-Safe does not have an Apple logo stamped into both sides it is a knockoff and may damage your Mac
さんによる
@mayer thank you for the info!
さんによる
コメントを追加
回答を追加する
Daniel Mazariego さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 79
今までの合計 583
