メインコンテンツにスキップ
A2115 / 2019 / プロセッサ3.0 GHz 6-core i5, 最大3.6 GHz 8-core i9. 発売日は2019年3月19日
131回答 すべてを表示
When should I open my computer and dust it out?
A few months ago, I bought my 5K iMac with powerful specifications, including the 8 core 9th-gen i9 (I now realize that the CPU is socketed and I should have saved money by doing my own operation) and Vega 48 with 8GB VRAM. I use this computer quite often for all of my school work, some video content, and gaming on Windows Bootcamp.
I am aware that dust buildup in the machine can cause thermal throttling over time and can damage the device. Since I have spent so much on this computer, I look forward to buying adhesive strips, opening the computer, and then dusting it off and closing it up (possibly doing some upgrades on the inside using the vacant PCIe slots or putting in a new CPU in 5 years). With all these things considered (how often I use it and all of the technology in there that tends to get hot), when is the best time I should schedule to open the computer and do the dust off? Obviously it’s inconvenient to get inside and requires single-use parts like adhesive, and so I can’t just “check on the dustiness” every so often.
I am wondering if anybody has an estimate of when my computer will start to collect enough dust that it needs to be cleaned out before it damages the computer, perhaps in "x months after you bought the machine” or after the machine starts behaving in a certain way. Is there a routine test I should be running to determine this instead, especially if dust collection is extremely variable from system to system and no estimate is reliable? Thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
First you should take the time to review the iMac Intel 27" Retina 5K Display Teardown while is an older model its basically the same as yours.
There is very little one can do internally from an upgrade perspective, so don’t over think what you can do here.
As for dust build up I would say every two or so years is about when you’ll need to worry about it. So relax you’ve got plenty of time! The important things are making sure the room you are using it is as dust free as you can make it and use a good surge suppressor or better yet get a UPS. In addition, if you live in a humid area get a dehumidifier and if you live in a very dry area or cold in the winter getting a humidifier. Controlling moisture that can condense on your gear or the risk of static damage when its too dry are the things you can do to prolong your systems life.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Andrew Howe さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 97
