メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kohlerは、一般家庭用および業務用を問わず、多くの乗用芝刈り機やガーデントラクター向けのガソリンエンジンを製造しています。
Mower just clicks won't start
I have a cub cadet lt1050. It's been having problems starting so I replaced the battery and it worked for a while then it started having problems again and I would hammer on the starter to get it going. Now it won’t start no matter what I do. Ive tried jumping the selnoid and it still just clicks. What should I try next?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Don't ever bang on the starter believe it or not it's not good for it maybe tapping on the bottom is ok but you can seriously mess up the inside of the starter I went to pick up a starter whose been working on them for 35 years and over heard him telling someone else that
さんによる
Try turning the engine over by hand it might be the starter is locked into the flywheel
さんによる
コメントを追加
2件の回答
ベストアンサー
Hey Seth.
I’d just make sure the electrical connections between the battery, solenoid and starter are sound, and the battery is fully charged. If the key switch won’t start it, and your jumping the solenoid won’t either, then it’s almost sure the problem is with the starter. Sometimes the gear that engages the flywheel is made of plastic, and it wears over time, requiring replacement of the gear only, instead of the whole starter. Either way, the starter removal and installation is fairly straight forward and simple (don’t forget to remove the ground from the battery before you start).
Good Luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Starter Assist Relay should fix it up. Cheap fix.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Seth Gomez さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 51
今までの合計 14,731
