メインコンテンツにスキップ
A collection of guides and support to help with washer repair.
3478回答 すべてを表示
kenmore 400 series top load washer fills up with water but wont comple
washer fills up wth water but won’t start washing the clothes.. i unplugged machine from power source and left unplugged for a while . when i plugged machine back into power source and then turned machine on at stopped cycle ,machine would finish wash cyle. i changed the starter unit and it worked fine for two days. washer then would stop working at diferent cycles. i would turn off washer and  unplug washer from  power source.  i would leave washer unplugged for a while and  then plug  it into power source. i then pulled  the  on knob at the stopped cycle and the machine would cycle thru.  i  bypassed the lid switch  and the machine cycled thru to the last rinse cycle before stopping. i unplugged the machine,waited for awhile,then plugged the machione back into power source. i pulled the on knob and the machine cycled thru.  i checked the voltage from power source and it was at 120 volts. pleeeeaase  help with this mystery !!!!!!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
Hey Nigel. Can you give us the model number for your washer? Also, any faults or error codes on display?
さんによる
29422801 is my model number
さんによる
コメントを追加
1 件の回答
Timer
The timer might be defective. The timer is frequently misdiagnosed—before replacing the timer, first check all of the more commonly defective parts. To determine if the timer is defective, consult your washer’s wiring diagram and use a multimeter to test the timer for continuity.
https://www.repairclinic.com/PartDetail/...
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer may stop mid-cycle. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
Water Inlet Valve
During the rinse cycle, the water inlet valve opens to allow water to enter the wash tub. If the water inlet valve fails, the washer will continue waiting for the water to enter the washer, causing it to stop mid-cycle. To determine if the water inlet valve is defective, use a multimeter to test it for continuity. If the water inlet valve does not have continuity, replace it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nigel Vinson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 26
今までの合計 1,650
