kenmore 400 series top load washer fills up with water but wont comple
washer fills up wth water but won’t start washing the clothes.. i unplugged machine from power source and left unplugged for a while . when i plugged machine back into power source and then turned machine on at stopped cycle ,machine would finish wash cyle. i changed the starter unit and it worked fine for two days. washer then would stop working at diferent cycles. i would turn off washer and unplug washer from power source. i would leave washer unplugged for a while and then plug it into power source. i then pulled the on knob at the stopped cycle and the machine would cycle thru. i bypassed the lid switch and the machine cycled thru to the last rinse cycle before stopping. i unplugged the machine,waited for awhile,then plugged the machione back into power source. i pulled the on knob and the machine cycled thru. i checked the voltage from power source and it was at 120 volts. pleeeeaase help with this mystery !!!!!!!
Hey Nigel. Can you give us the model number for your washer? Also, any faults or error codes on display?
Tony さんによる
29422801 is my model number
Coach Clever さんによる
