メインコンテンツにスキップ
2017年Appleは13インチMacBook Airに新Broadwell Intl Core i5プロセッサを搭載して登場させました。バッテリー寿命の改善とパフォーマンスがわずかに向上しました。
423回答 すべてを表示
SMC goes back to normal after resetting
Hi, I have a Macbook air from 2017, just got it under a month ago… I have tried resetting the SMC many times and it has successfully worked fine… although after a couple of days, it is back to normal again… I do this because the batterylife is draining a little too fast and the fan makes loud noises without having barely anything open. I was thinking if there was a way so I didn’t have to reset the SMC all the time? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
First lets double check the battery install this app CoconutBattery take a snapshot and port it here for us to see iFixitでの質問に画像を追加する方法
But even still you likely have a simple issue! Check your drives free space is it at least 1/4 of the total space of your drive? If not you’ll need to clean off some of your stuff. If you have a smaller 128 GB model you’ll want 1/3 free.
What happens is the SSD drive needs to recover space by applying wear-leveling so the free space is not over stressed from Virtial RAM and other uses each time an app is loaded.
このアンサーは役に立ちましたか?
スコア -1
2 件のコメント:
Hi, thanks for the help! The problem is that barely have anything on my computer because it’s brand new. When I use it, I never have more than 2 tabs open while using safari.
さんによる
I would recommend you copy off your stuff and then return the system to the seller as it likely needs repairs. This is not normal!
さんによる
コメントを追加
回答を追加する
Littleplant さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 40
