メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたTV用ゲームコンソールです。PlayStation 4 Slim (CUH-2000シリーズ)はSP4の薄型モデルです。2016年9月7日に発売されました。
570回答 すべてを表示
PS4 Slim HDMI Filters
I recently had a ps4 slim with no signal, I swapped the hdmi port, I also had to swap a couple of HDMI filters (I dislodged and lost them) I bought some what where advertised on ebay as PS4 slim/pro HDMI filters, and although they were a little big I managed to get them in. I now have a signal but its was something like 640 x 480, it was mainly black but had a couple of colored lines up one side of the screen. I think replacing the filters would fix it but I’m having a real issue sourcing them, which is making me question if its at all possible to buy them?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Was the previous port not physically damaged? I’m thinking the problem would be caused by the HDMI encoder IC instead.
The dislodged part makes it a bit tricky as that can be caused by bad solder joints / connections behind the HDMI port pins.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No damage that I could see, it was getting no signal, I swapped the port and 2 HDMI filters, the HDMI filters where sold as PS4 slim filters, these are slightly smaller and I think were falsely advertised because the one I have put in look like they have come from a standard PS4. Since the change I now do have a signal but its of a black screen (fuzzy) and a couple of colored lines.
さんによる
コメントを追加
I have the exact same problem. Did you ever find the correct one's for the slim?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Steve Fishwick さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 11
今までの合計 844
