メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
Vacum, and fuel hoses hooup
I required to clean out the carburetor on my 125 Yamaha Vino, and the vacuum, and fuel lines got mixed up. I need to install them in the right places where they should be, can anyone help with a diagram instruction on where they are attached on the carb?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I already have that manual, and still the vacuum hose hook-up locations to the carb are not shown, or explained. I had to remove the carb to clean it inside of old fuel residue of 10 yrs. siting idle. Though service manual would cover the subject, before I removed the carb, but later found it wasn’t covered at all. I pretty much had to guess, which hose went where, once I re-installed the carb., and lucky me, I figured the issue out. Scooter runs perfectly again, and fired up on the first turn over, the way I hooked it up…. Thanks for the effort in helping
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hey va3grp.
Scooters are not my thing, but I did look into it, and found an actual service manual for your model. Lots of useful information and loaded with diagrams that should supply what you need. Just do a search for “YJ125S Service Manual - 49ccScoot.com”, and the pdf manual can be downloaded, or you can simply view it’s contents on line.
Good Luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
va3grp さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 30
今までの合計 2,320
