メインコンテンツにスキップ
Model番号 A1225 / Mid 2007とEarly 2008 / 2.4, 2.8もしくは3.06 GHz Core 2 Duoプロセッサ
434回答 すべてを表示
Power adapter - multiple choice, please help!
Hi!
My power supply is faulty on my iMac and I need a replacement. The faulty supply inside my 2007 24 inch iMac is a LiteOn PA 3241 02A1.
In my research, it appears that another power supply is also a compatible replacement. A Delta ADP 240 AF B. These seem to have been fitted to the 2008 version of the iMac 24 inch.
Is this the case that either can be used as a replacement for my 2007 iMac?
Thanks for your help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Apple contracted both companies (Delta & LiteOn) to make power supplies. As long as you get the correct one for this series you’ll be OK. Here’s a good rundown of the Apple P/N’s per each model. This is from PowerbookMedic’s parts listing 250W power supply
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Thanks for this information @danj . That’s really useful.
So just to confirm, you mean that any power supply made for the 2007-2009 Intel iMac 24 inch will work fine, it’s just that the Apple product numbers and actual supplies may look a little different? Have I got that correct?
Thanks for your support.
さんによる
If it’s helpful. This is my current faulty power supply. https://share.icloud.com/photos/0VsYhICk...
This is the replacement I’m looking at.
https://share.icloud.com/photos/0Np6SZk0...
Thank you.
さんによる
As long as its a 250 Watt unit and has one of the Apple part numbers listed you'll be OK.
さんによる
コメントを追加
回答を追加する
Sam Harries さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 257
