メインコンテンツにスキップ
Motorolaの最新モデルは2015年7月に発表されました。Quad HD付き1440 x 2560解像度をもつ5.7インチ IPS TFT LCDスクリーンには21メガピクセルのカメラが搭載されています。モデル番号はXT1570、XT1579、XT1575とXT1578です。
61回答 すべてを表示
Is it worth pursuing repairing my phone?
I accidentally drowned my phone (Moto X Pure Edition) several days ago on a kayaking trip. As soon as I could, I turned it off and put it in a bag with a silica gel packet I had with me. On the way home, it accidentally got turned on in my pocket, but the screen had stopped working by that point and I had no means of doing a full shut down, since holding the power button just seems to restart it. I transferred it to a bag with perhaps a cup of silica gel desiccant and left it for several days.
At present, the screen still does not work, but the motion controls for turning on the flashlight and the camera do work. I’ve also caught it activating alarms a few times. It seems that it will charge the battery (since when I initially tried it, nothing happened at all, but it started doing a little bit after leaving it on the charger), but the computer does not register a device being plugged into it if I connect it by USB.
Does this sound like enough is working that it would be worth trying to repair it, or should I just go ahead and seek out a new phone? Thankfully, I’ve been pretty good about transferring pictures to my computer, so the only things I would seriously lose are the pictures from that trip.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @sir_tarin
You could always try cleaning the phone as described below and see if that works. At this stage you’ve got nothing to lose and everything to gain ;-)
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
Dessicant and other products such as rice do not fix the problems caused by corrosion.
Rice Is for Dinner, Not Repair
First do not turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do need to use it, check the label to verify the amount of IPA.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone.
Moto X Pure Edition
If this process seems too daunting, after opening the phone and inspecting the damage, if you deem it still worthwhile, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Anthony Hamilton さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 43
