Why does my computer constantly whirl and make noise?
all in one computer, very loud and slow when machine is whirling.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
This to me sounds like a possible cooling issue. The system probably needs to be cleaned out. Ideally the best option is to open the system up as much as you can and clean any dust out. At the very least try to use come compressed air. Just be careful of sensitive components.
このアンサーは役に立ちましたか?
Do you have the model of the all in one computer?
There should be a sticker label with the model of it behind the computer or in a removable cover.
Some models are built with very low end performing hardware. E.g like an AMD A4 processor and a 5200RPM 500GB laptop hard drive which will cause the computer to run very slow.
Does it run slow from the very beginning where it loads windows and using it in general?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 10
今までの合計 380
1件のコメント
Joe Pierce what model is your computer and what have you checked?
oldturkey03 さんによる
