メインコンテンツにスキップ
Repair guides and support for motorcycles manufactured by Honda.
75回答 すべてを表示
How can I use this LED strip light with 2 negative wires and 1 positiv
I bought this LED strip wire for my tail light, usually the connection is 1(+) for tail, 1(+) for brake, and 1(-) for ground, but this LED strip had caused me headache switching the wires, results are confusing but both red(brake) and orange(tail) lights should work separately.
Update (06/27/2019)
this is where I bought the Led strip. I so wsnt to make it work
https://s.lazada.com.ph/s.ItpX
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
cari valentin what model is your bike and what model is your LED strip? Post some images of all the stuff you have with your question. that way we can seee what you see. iFixitでの質問に画像を追加する方法
さんによる
Hi oldturkey03, it's a local brand Rusi Mojo 110 -here in Philippines (ducati monster 696 look alike)
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I am going to need a bit more information to assist you with this. Please provide me with the make and model of the motorcycle so that I can pull up the wire harness and also a picture or link to the LED you are attempting to use.
Then I can help you a little more. The brake light will also need to be capable of running as a running lamp. as well as triggering a brake light.
This might help you also
https://www.twistedthrottle.com/blog/how...
Cheers!!
Monte
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hi Montgomery, thank you. My motorcycle has a local brand here in Philippines which is Rusi Mojo 110 (ducati monster look alike) but the LED strip I bought was from I guess China, I got used to 3-wire connection for tail lights and it's always only 1 ground. I will send you some pictures shortly.
さんによる
Originally, my tail light has around 10 LEDs but when some aren't working, my dad did some soldering so he was still able to keep 5 LEDs on as tail light/running lamp, they stay on but I tapped a turn signal bulb as the brake light because it's only a 2-wire connection + and - |
Where can I send the pictures best?
さんによる
Sorry I didn’t see this notification, anyway if you want to send the pictures still you can send it to Montgomerykern@icloud.com
さんによる
コメントを追加
回答を追加する
cari valentin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 428
