lens keeps stopping and not going in or out
Hello, I actually have a Canon PowerShot ELPH 360 and after an accidental drop, the lens will not always go in or out….how can I get this fixed?
Can I fix it myself??
Thank you for any help
Your lens assembly slides within the two or three helical tubes that screw in and out to extend the Lens forward. Either the tubes have jumped their slots or the lens assembly has.
You will need to find the service manual or find a camera repair shop that can take the assembly apart to fix, it also may need some replacement parts if they are damaged.
このアンサーは役に立ちましたか?
check on here for some ideas on how to unstick it. If none of those work consider replacing your lens assembly. Repairs of the assembly are very tough due to the lack of spare parts. To replace the lens assembly use this guide Canon PowerShot ELPH 300HS Lens Zoom Unit Replacement Replacements are available at places like ebay for no more than $20USD
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 129
1件のコメント
Also it says Lens Error, and won't close
Crystal さんによる
