メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
MacBook random shutdowns when not connected to power after SMC reset
My macbook pro 13” retina late 2015 shuts down randomly since yesterday. First time battery was at 50% and could only be revived when attaching the computer to power and then turning it on. Now it also shuts down randomly at 80%. The computer has not yet shut down randomly when attached to power and does not shut down immediately after disconnecting the power cord. It seems he keeps working till 80% and then shuts down. As this all pointed towards battery problem i have tried to reset the SMC already two times but it does not work.
Cycle count = 850
Status battery according to apple = normal
With coconut: status battery = good, but design capacity is only 40%.
What can I do? Should the battery definitely be replaced?
Is there a possibility the whole pc will crash and not be able to be rebooted even with power connected?
Any tips are welcome as I really need my computer the coming days !
THANKS
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
With those symptoms and a low battery health of 40% I recommend getting the battery replaced as it’s not holding its charge well to provide enough power at 80% or less to keep the MacBook on.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Pauline さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 49
