メインコンテンツにスキップ
2.4GHz, 2.7GHzもしくは2.8GHz クアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大 3.8GHz) with 6MB 共有 L3 キャッシュ。
275回答 すべてを表示
2013 MacBook Pro 15" Retina powers on with cable, but not batter alone
Hi guys,
I recently dropped my 15” Early 2013 Macbook Pro Retina and it landed on the right corner. Now, it won’t turn on, unless it’s plugged in to a power source.
I recently went in and disconnected all the wires and reconnected them, still same problem.
Here’s my system report - Charge Information:
  •   Charge Remaining (mAh): 7783
  •   Fully Charged: Yes
  •   Charging: No
  •   Full Charge Capacity (mAh): 7981
  •   Health Information:
  •   Cycle Count: 53
  •   Condition: Replace Now
  •   Battery Installed: Yes
  •   Amperage (mA): 0
  •   Voltage (mV): 12415
Does anybody have a solution to this?
Do I just need a new battery, or is there an easier solution to this problem?
Note: The low cycle count is because I replaced the battery just 6 months ago.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Condition: Replace Now - Is a good clue this battery has issues. As you just replaced it I would contact the person who sold you the battery for an exchange as its likely defective.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks @danj, I purchased from here and already have a warranty battery on the way
さんによる
コメントを追加
That might be either a problem with the charger, or a problem with one of the connections from the charger to the battery.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Battery shows 100% charged when I’m powered on (which can only happen when plugged in.
さんによる
@drochwalik Then it means that the battery isn't retaining any charge, which means that the battery needs to be replaced. However, don't take it to apple, they will probably overcharge for it. If you want to fix it yourself, try looking at a teardown.
さんによる
コメントを追加
回答を追加する
Derrik Rochwalik さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 63
