メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1199回答 すべてを表示
X keeps restarting after new charging flex.
Phone keeps restarting after around 3 minutes. Customer came in for charging port replacement. All screws in right place, no long screw damage.
It has had the following to rule out:
Battery and 3 replacement ports. Each flex cable was unplugged one by one to troubleshoot, even with the following unplugged it occurs: Screen Flex (Both), Face ID/Front Cam Flex (All 3), Antenna Flex (Wifi), Lower Antenna, Power Button Flex/Flash & Volume Button Flex & Charging Flex.
I have tried a replacement screen and still occurs. I have checked all the FPC under microscope and very clean and tidy. It cannot be the port surely as it occurs even when not plugged in.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
14 件のコメント
Did you find out what the issue was? I did the same repair with the same results.
さんによる
I will be grateful for info how did you fixed that issue. Thanks
さんによる
How did you fix it?
さんによる
In my case the new charging interface was a problem. When I returned to original part with faulty microphone the problem didn’t returned.
さんによる
im facing this same issue now on iphone X keeps restarting after charging flex replacement . any solutions please ?
さんによる
9件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
Assuming it was working fine prior to your repair attempt, then I would take a closer look at the small components surrounding the connectors. If you see anything dislodged or damaged, then that would probably cause your issue. At this point, you may need to have this looked at by an experienced micro-solderer.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
最も参考になった回答
So apparently after some investigation, this appears to be an issue with 3rd party charge port cables. Apparently in iOS 13+, there is software that monitors thermal readings from the charge port modules and the 3rd party cables do not allow this to happen which triggers a kernel panic, restarting the phone.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Is there any fix for this?
さんによる
Is their a particular prank or place to look for the replacement that has the sensor
さんによる
コメントを追加
回答を追加する
Phone Repairz NE LTD さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 6,407
