メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1999年に発売。初代PowerMac G3の後継機。300-450 MHz、64または128 MBのRAM、6または12 GB HDDを搭載。
won't power on
Hello!
I am also having the same problem. I did what u suggested and nothing. I opened the computer and I noticed that 1 of the plugs P5 was not connected to anything. My question is should that part be connected and if so where? Maybe that is what is causing my G3 not to power up?
Thank you.
Edie
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Please start a new question as this one has been answered and almost no one will now look at it. Thanks
さんによる
コメントを追加
1 件の回答
ベストアンサー
The Plug "P5" is just another 4-Pin Molex power connector. It is used to power a secondary hard drive, and doesn't need to be connected to anything for the computer to work. If the computer isn't powering on, a bad power supply may be to blame. The PowerMac G3 Blue and White (as opposed to newer/older powermacs) uses a standard PC "ATX" power supply. You can buy these at just about any store that sells PC parts, or use an existing one if you happen to have one handy.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
edith さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 13
今までの合計 1,506
