メインコンテンツにスキップ
Released March 2016, 7.0" Galaxy Tablet by Samsung.
47回答 すべてを表示
galaxy tab not charging show icon but no percentage
i got this tablet fom a client, when i plug it with my original galaxy s8 cable, just showed it was charging, after a few hours, the tablet turned on by its own.
i never knew what i did, maybe was the cable, but im not sure, i didnt use either the fast charging brick because it didnt recognized
just to add, i used the method that i saw on youtube, setting it on download mode, and helped to boot again.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Actally what I did I used my personal charger and started to working again a fast charge and a closely similar cable works
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Sometimes the customers charger and/or cable may be at fault.
With a good charger and cable if it gets stuck on the charging bolt for a bit it usually means battery is too flat and needs time to charge up.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I have the Samsung tab A and I’ve tried to reboot it and nothing works it just goes back to the charging logo with lighting bolt with no percantage please help
さんによる
コメントを追加
回答を追加する
armandomh91 さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 51
過去 30 日: 261
今までの合計 13,263
