メインコンテンツにスキップ
2013年10月22日に発表され、11月12日に発売されました。iPad mini 2はRetina Displayが搭載された iPad miniとしても知られており、小サイズ7.9インチのフォームファクタのiPad Airに全ピクセルが詰め込まれています。
426回答 すべてを表示
Why is my LCD flickering black after replacement
I just replaced an iPad mini screen and LCD. The display keeps flickering black. If I hold the power button it turns back on and shows the power off and the display. It seems that the new screen I put on is defective and the digitizer isn’t working, but that shouldn’t be affecting the LCD. I checked and made sure it’s connected fine, and it is.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
The LCD has a full picture, but the sleep Button is not putting it to sleep or waking it up, it only comes on when I hold the sleep button and then the screen comes up to turn off the iPad. It has stopped flickering black
さんによる
コメントを追加
2件の回答
最も参考になった回答
Was the battery disconnected when plugging or plugging in the screen display?
If not, the backlight filter may be blown and needs to be replaced. This can be confirmed by trying the old screen and/or shining a flashlight on the replacement screen and see if an image can still be seen but very dim.
The logic board can be repaired by someone reputable that is experienced in micro-soldering / board-repairs for iPads. You may find someone locally that offers this kind of service.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Do check the cables when you connected the iPad LCD screen… I do agree with ben but be sure that you have connected the LCD correctly placed in the socket, because sometimes we accidently make mistakes when replacing LCDs on our devices… right?
The way I do it is not put pressure in the middle of the socket but rather start by pressing the sides gently (right - left)… I did screen replacement when i was entering smartphone repairing industry and mostly failed miserably because I damaged the socket by exerting a little force when connecting screens.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alexandria Duncan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 284
