One of the USB ports has stopped working
So i have the old model ps4 that first came out, and now one of the two USB ports has stopped working, the other one is working perfectly fine though. So anyone knows what's the issue here?
Usually dust gets stuck in them. It takes quite a bit of effort to get dust off them with a fine brush but that usually does the trick. Otherwise dousing a USB cable in alcohol and re-inserting the cable into the port multiple times may clean up the connection.
このアンサーは役に立ちましたか?
Already have done that, did not work. Although when i connect something like a ps4 dock that has fans and a small light to the faulty USB port, the small light does light up blue but if i pressed the button on the dock to turn the fans on the light powers off and the fans doesn't spin and again if i turned off the button the light light up again...
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 476
