メインコンテンツにスキップ
2012年6月発売。Core i7プロセッサ 、Turbo Boost / 最大1 GB DDR5 Video RAM
597回答 すべてを表示
Can I retrieve an object from the headphone jack hole?
A bead fell in the headphone jack hole of my Mac and got stuck in there. Any recommendations for how to get it out? My attempts have given me no results and I think the bead could have gone further in.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
If we knew your specific machine, we could give you better advice. Some Mac have a separate I/O board.
さんによる
When I put my serial number on the apple website it says I have a MacBook Pro (15-inch, Mid 2012)
さんによる
コメントを追加
2件の回答
ベストアンサー
Ouch, bad luck! If it’s made of metal a magnet might do the trick. If not I’d try sucking it out with a vacuum cleaner or trying blowing it out with canned air, it depends on the size of the bead. If you have a very steady hand you may also try a broken toothpick with some glue on the tip. As a last resort you might buy very fine pointed tweezers such as the ones used for phone repairs. Wish you luck..
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I would second the glue idea, while reemphasizing the steady hand! You don't want to get any glue on the sides of the jack, otherwise you'd just as well have a bead in there because the glue will get in the way of the headphone plug!
さんによる
コメントを追加
It’s easier to take out the headphone jack and operate on it standalone.
Or just replace it since you already removed it from the computer.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Isa さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 82
