メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Black tape over iPhone 4S logic board. What is it?
While refurbishing an iPhone 4S, I noticed that some tape had fallen off the EMI shield covering the Qualcomm MDM6610 chipset.
What I initially thought was some insulating tape was actually rigid transparent film with black coating on one side that could be removed using a fingernail.
Is there any purpose to this tape such as heat dissipation or EMI protection? What is the black substance coating the film, and is there any point replacing the tape as part of refurbishment? (The film had lost its adhesiveness so can't be reattached in its present condition).
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The black tape is for heat transfer and acts like a heat dissipator. The metal shields are EMI shields.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thanks for your reply. What is the black substance, out of interest? Are there any handling precautions for it?
さんによる
I think it may be graphite material for acting as a heat dissipation. Otherwise it would be lead but lead can't be used when manufacturing.
さんによる
コメントを追加
回答を追加する
John Watts さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 559
