メインコンテンツにスキップ
Repair and disassembly guides for the Jura (Capresso) Impressa Series J coffee maker.
23回答 すべてを表示
Why did my water pump come on and will not stop?
The water pump on my J5 came on in the late hours of the night *by itself*. It constantly runs. Why did the pump come on 12 hours after the machine was turned off? A short?
At this time, the pump runs when i turn the power on. The display shows “warming” until the water in the tank runs out. The brew group has been maintained and the water is draining into the grounds container. Cleaning/descaling current.
So, what phantom is in my machine? What gives the pump instructions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Jura Drainageventil zerlegen, Anleitung 2
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thank you! Update: I broke the gearbox to the lower part of the brew group. I know now how to reassemble it. Also, there was quite a buildup of old coffee before I refurbished it minus the broken gearbox.
So, until I find a gearbox, I will not be able to test the machine. I am still curious why the machine turned on late at night and the pump ran. I happened to be up and luckily heard the commotion. So here's a summary:
1. Machine was off for at least 12 hours. The unit powered up and the pump ran and will not stop.
2. The display reads "warming" while I refill the tank and quickly empty the tray. Never reached temp
3. The pump runs until I unplug the machine.
さんによる
* I did not power up the machine in line 1.
さんによる
コメントを追加
回答を追加する
Richard Lewis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 22
今までの合計 673
