Can you replace just the front glass?
So, I have seen videos about freezing the GS8, and removing the front screen super duper easy. Can this be done with heat and slowly pulling the glass off?
Its not super duper easy even with freezing then comes the fun part lol
Feel free to have a go as theres nothing really to loose apart from a glass lens order the full screen assembly as well at the same time though so u have it just in case
このアンサーは役に立ちましたか?
I have a lot of friends working in big companies of refurbishing and even with 20,000 dollars in machines there is a 45% of failure. Removing the glass is the first step, next is cleaning a installing OCA and removing air bubbles or cheap way using LOCA. For sure is not easy without good equipment but is possible.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 89
