iPhone X long screw damage/RF board component transplant
The RF board has long screw damage causing sound and performance issue. The PCB has so many layers which means it’s almost impossible to trace and connect the missing links. Can the RF chips be transferred to other RF working board? My assumption is only LTE, WiFi and Bluetooth chips are necessary to be transferred. Please let me know your thoughts.
この質問は役に立ちましたか?
1件のコメント
IPhone X has two boards fused (main board and RF Board) My issue is within the circuitry of the RF board. Would it not cause issues when the RF boards are swapped? RF board has LTE, WiFi modem etc which might be hard-coded to the main CPU. If I can borrow a working RF board and transfer the important chips, my issue will be sorted. The question is if it can be done, what are chips that needs transferring? It’s impossible to move everything including caps and registers.
bijaya.pun さんによる
