Is Rear housing compatible for iMac late 2013 and 2015?
I have a late 2015 iMac 4K (21.5) Power button broke. There is late 2013 rear housing on sale on eBay. Is the housing compatible? Both have the same A1418 number on the back?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here are the parts in question for reference:
Late 2015 iMac 21.5" Rear Housing Unit (15) Grade-B - Apple P/N 923-00556
Late 2012/13 iMac 21.5" Rear Housing Unit (12/13) Grade-B - Apple P/N 923-0449
There are some differences between these while minor will make using the the older case difficult as the microphone is located at a different location and the WiFi & Bluetooth antenna’s are located differently.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 196
1件のコメント
What do you mean the power button broke? Can you explain and if possible post some pictures iFixitでの質問に画像を追加する方法.
There might be a way you can fix this saving you some bucks!
Dan さんによる
