Constant Memory Card Error
I keep getting “Memory Card Error” no matter how many cards I try. Can it be fixed? Thanks
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you are formating the cards on PC, are you using FAT32 or exFAT (or NTFS?)? You should format your card to FAT32.
このアンサーは役に立ちましたか?
Thank you so much for your help. I was formatting at the incorrect settings. Thanks again. Best news I have received in a long, long time.
Irving E. Carlson
Owner
Carlson Studios
Can someone please explain "formatting a card on PC"? I just got a new memory card from Amazon and "memory Card Error" appears with old and this new card"Tab on side is in up position. Sheila, Senior Citizen. Thank you.
Thank you for share with us.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 315
1件のコメント
Are you able format it?
mike さんによる
