MacBook screen really dim at 100% brightness
I have a MacBook that you can somewhat use with a flashlight no matter what way I tilt the brightness it just stays dim where I cant see it please help
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try resetting PRAM; at startup press command+option+P+R until you hear a second boot chime then release. If that doesn’t help it might be you have a faulty keyboard or a faulty backlight circuit, but unfortunately there’s no way to tell exactly which of the two without some basic logic board testing.
このアンサーは役に立ちましたか?
Most likely the CCFL's and/or the inverter are worn out
過去 24時間: 2
過去 7 日: 7
過去 30 日: 10
今までの合計 98
