メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
After screen replacment works then stops after a few weeks.
I have a iphone 6, i replaced the screen and it worked for a while then it stopped working. i heard it could be because when you put the cables and put the screen back on you have to bend them a special way. When i get the new screen(Again) Can somebody tell me how to bend them the special way if thtas true or how to fix my old one, Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Lol I love these bend them the special way things lol
When u say it stopped working how did it stop working was it dropped… how high was the drop
Replace the screen put the metal plate back on with its screws dont mix up the screw order and it should be ok
When it's working go slap the person who told u to bend it the special way in the face :)
How did it stop working? Blank screen, fuzzy colours, no touch etc
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
Lol ok, So i left it on the charger one night and the next day it wouldn’t work. The back light was on but no display. After it was off for a while i removed the battery. It was so old it couldn’t even hold the phone on for a minute. Sorry this isn't answerd i accidently did that...
さんによる
So was the phone on a good quality charger and do u get signs now the phone is on and working and just the screen isn't??? Eg does it vibrate does it ring etc
さんによる
When I had the battery in before I tossed it the LCD lit up so I could tell it was on but no os seen. Does it madder how I had the cables when I closed it up?
さんによる
As long as ur not damaging the cables and crushing them in any way and the screws are in the right holes and u havent caused long screw damage it shouldnt matter... u can have damaged screens where the flex is damaged and bending it can cause it to stop working but if its been working for a while it's not likely the case... common thing for screen problems a few weeks later are usually a broken screen or shorted backlight caused by the sticker covering the backlight solder point being out of place and shorting against the metal plate.
さんによる
So what should I do?
さんによる
3件以上のコメントを表示
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dylan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 76
