メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
Touch ID not working after battery swap
Alrighty, so I had done a battery swap on this phone. Before hand, everything worked and I had checked everything. For the battery swap, I took the screen off just to make sure I don’t accidentally rip the ribbon cables. When I got done, I put everything together and the Touch ID wouldn’t work. What’s weird is the home button would work. I tried reconnecting the screen hoping the connections were off but that didn’t fix anything. I went to the extent of taking the home button off and checking to see if there were any micro tears. I couldn’t see anything that was wrong so I reconnected everything and again, the Touch ID wouldn’t work but the home button would work. I’m at a lost of what could have gone wrong. If anyone has any ideas, please let me know.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
Well usually it's either dislodged or missing components near screen connector or the screen got somehow damaged.
Definitely need to try another screen as this is a common fault that is usually solved by a screen replacement.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
I put a new screen on and it had fixed it. Ill look around the screen connection to see if there is something missing. Thank you!
さんによる
コメントを追加
What happens when you go to settings and try to set touch ID? I find it really weird that touch ID stopped working but the home button function still works.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I backed up the phone and did a factory reset. When setting it up it prompts you to use the Touch ID and I would try to put my finger print in. It wouldn’t read my finger but if I pressed too hard it would tell me that I need to press softer. I haven’t tried a new screen but I will try that, I just find it really odd because it is the factory screen and hasn’t been tampered with.
さんによる
Update: I put a new screen on it and the Touch ID is now working. Does anyone know why the original screen would eliminate the Touch ID?
さんによる
It is not the fault of the screen. There was likely damage to the ribbon cable that you could not see. I have had this same issue with a replacement 7 Plus screen. I suspect the screen was returned but then tested by the seller and showed the LCD/Digitizer were good so they resold it to me. Something was likely pulled or twisted just a tiny bit too much and cause unseen damage.
さんによる
コメントを追加
Here are my thoughts looking through what other have posted. I ran into an issue where I was working on an iPhone 7 and tore the home button extender cable because the screen slipped on me as I was opening the device. It’s possible that’s what happened here. Was the screen an original part from Apple or was it a replacement? It’s possible that if it was an aftermarket part, there could have been some damaged done already and reopening the device finished it off.
A few other thoughts are pinched cables can sometime cause odd things to happen but it sounds like a new screen solved the problem. There is a lot of room to play with the connectors on the screen on this model but you always need to be aware of how much tension you put on the cables as well.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I believe it was a bent/pinched cable. The screen that was on it was an Apple screen. I put on an aftermarket one and it had fixed it. Thank you for the insight though!
さんによる
コメントを追加
Touch flex can be broken while open the phones or possible connector damage,You have to check the screw hole might me problem by long screw.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ely Sellin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 164
