メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1200回答 すべてを表示
Back camera and flash not working
I changed the screen of and iPhone X for an client.
He sent me an email now saying . “Screen repair is awesome, no faults only issue is back camera and flashlight is not working. Face-ID and front camera is working fine.
First time I had this issue now, same procedure as any other iPhone X repairs I have done.
Anyone know a simple solution to this issue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I would check for pry damage near the FCAM (J4600) connector as it is directly adjacent to the RCAM Zoom connector (J4000). Specifically, check Q3700 as those glass transistors are easily damaged but there are a whole slew of passives surrounding the connectors that could also be damaged.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Cant really see any particular damage here.
can it be damage from the fall of the screen, it was very damaged and not turning on
さんによる
The other issue with the X is that the logic boards are very thin and flexy. It is probably some cracked solder ball in the RCAM circuit.
さんによる
コメントを追加
回答を追加する
nicolay.94 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,718
