メインコンテンツにスキップ
2014年4月のアップデートによりアップルの13インチMacBook Airはデュアルコアi5またはi7プロセッサーの更新とわずかなバッテリー性能の向上がされました。
313回答 すべてを表示
Unit stops charging when powered
I have a macbook air that all of a sudden stopped charging, but still powers up fine with the charger.
The mag safe light does lights up amber, but it does not turn green and the charge indicator on the macbook shows that its charging, but the charge does not increase. This sounds like a logicboard problem, but could it be the battery?
Update (05/17/2019)
Here is a screenshot of the coconut battery tool for the poster who asked me for a exported report of the tool. I was not able to extract the data from the tool itself.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Let take a look at the battery with a better tools. Please download, install and run Coconut Battery and post your results.
https://www.coconut-flavour.com/coconutb...
UPDATE
That battery shows to be poor condition with 1,022 cycles. It will only hold 1/3 of its original capacity. Time to replace it.
Here’s how to change it out:
MacBook Air 13インチ Early 2014 バッテリーの交換
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
I did a Mac Data CSV Export but its just showing the field headers and not the actual data. Do I need to select something first? Please see the image I could only attach my original post.
さんによる
コメントを追加
Maybe the power consumption is equal to the power being delivered by the charger? Try emptying the battery, charging with the laptop off, than seeing if the charge has increased.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
That seemed to do it.. Why is it not charging the battery to full?
さんによる
Miscalibrated? Or maybe just a weirdly made battery... I'm not sure.
さんによる
コメントを追加
回答を追加する
Scott Larson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 78
