メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
745回答 すべてを表示
Screen and Keyboard not backlit
I just finished replacing the LVDS cable for someone who had inadvertently cut their cable. Now that I've hooked the LVDS cable to the screen and logic board when I power the computer on I get no light, they keyboard will not light up nor will the screen. I can see that there is stuff on the screen so I know that the LVDS cable works. What controls the light to the screen and keyboard and is there anything that I should check before buying that part. This is a Macbook pro 13" 2.26ghz intel core 2 duo. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
It's now called the display driver board. It looks like an inverter and is in the same place. Please give us the last three figures of your serial number so we know exactly which machine you have and can get you to the correct guide and parts.
Apple MacBook Pro "Core 2 Duo" 2.26 13" (SD/FW) Specs
Identifiers: Mid-2009 13" - MB990LL/A - MacBookPro5,5 - A1278 - 2326*
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
The last three digits are 66h. Thank you for your help
さんによる
Also, I don't know whether or not this could be related but the wireless card doesn't seem to work either, the card is in the computer but it doesn't show up in hardware on system profiler
さんによる
コメントを追加
回答を追加する
Trent さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 679
