Can I add discrete graphics to Mid 2014 MacBook Pro
Hi I have a retina macbook Mid 2014 with intel Iris graphics and wondered if I could add discrete graphics to it as an upgrade?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
There’s no way to do that.
このアンサーは役に立ちましたか?
This series came in two different configurations:
The logic boards are physically different! You can't add the GPU chip. You can only swap out the logic board which would be expensive!
Thanks Dan - that answers my question
If it was the 2016 or newer model with Thunderbolt 3 ports, I would have advised you to research the possibility of using an eGPU. I don't believe this is available for the model you have.
このアンサーは役に立ちましたか?
There are a few eGPU systems which work via Thunderbolt-2. At this point it would be a used unit.
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 271
