メインコンテンツにスキップ
A stand mixer originally by Ken Wood in Britain, now owned by De'Longhi.
74回答 すべてを表示
Pitch of sound of the machine changed overnight
Dear Readers,
I have had my Kenwood chef major (the large one) for about 3 years. I would like to know if I should worry about the machines change in the way it sounds.
Last week my machine started a making a different type sound than it used to. The pitch (tone) in the sound got much lower and deeper.
I have a suspicion it has to do with lubrication in the machine. I just would like to know if someone else can confirm that based on this description and if anyone maybe has some pointers on where to start if it is.
Kind regards,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@levi1 absolutely possible that this is an issue with your gears/lubrication. Usually a lack of it will make the pitch higher. Since we do not know your exact model, see if these guides Kenwood Chef will help you to check the gears and grease out.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I appreciate your response a lot.
The pitch however is much lower, so is it possible that might indicate another type of problem?
さんによる
Possibly an issue with the gears but you will have to take a look at it. For now, since it is only the sound that has changed, consider using it but monitor its performance.
さんによる
コメントを追加
回答を追加する
Levi Bimmel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 28
今までの合計 914
