My Sound has stopped only headphones work
Sound suddenly topped working, tried to restore it using online advice cannot.
Only headphone setting working,
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Part of the audio circuitry on the Air is included in the input/output board, which makes it easy to try solve the issue on a DIY basis at a relatively low cost. However be aware it’s not 100% sure the problem will be done with. If you want to try the repair this is the guide that would help you get the job done and it links you to the replacement part if you want to purchase it from iFixit:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 42
