Where can I buy pentalobe screws?
Where can I buy the eight 2.5 mm-long and two 8 mm-long external pentalobe screws for the back cover of the MacBook Air 11" (mid 2011)?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The discreet screws are these
Here’s one source for a full screw set Macbook Air 11" Screw Set - Bottom Case (10-15)
このアンサーは役に立ちましたか?
Thank you, Dan. Much appreciated. I have ordered from your suggested supplier and I'll post again when they arrive. Thanks again. - Mark
Hi again, Dan.
I can report that the correct screws and a suitable screwdriver were shipped from The Book Yard in Britain and arrived in Australia last week. Everything went smoothly - the payment, delivery and installation. Many thanks for your advice and suggestion. - Mark
Happy it all worked out! Don't forget to accept the answer.
I just herd in the news Australia is the top place most want see here in the states!
Just a question. Can these not be replced with philips screew or are they a custom thread?
このアンサーは役に立ちましたか?
They are custom thread so standard Phillips won't fit.
@aactech - The screws are a fine pitch metric. They are not easy found in small quantities on the open market. Recycled is often the best source.
At one point we looked for the older MacBook Pro's all we could find was 2k bulk boxes!
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 122
