メインコンテンツにスキップ
iMac はAppleのディスプレイ一体型デスクトップコンピューターのモデルラインです。
8382回答 すべてを表示
Where to store iTunes media after installing SSD?
I installed a 250GB SSD in the optic drive slot. It works great,, but for some reason all my music got installed on the SSD. The iTunes media is taking up way too much space on my SSD. How do I place the iTunes media on my original internal 1 TB hard drive? Will iTunes access the iTunes media if it's on my 1TB internal hard drive?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
In Preferences go to the Advance tab. There you can change the location. I would suggest you first copy your music to the new location, point iTunes to it and validate it works before deleting your music. To validate, close iTunes and rename your current iTunes music location to something else link iTunes.bak.
Not clear why it would have moved your music. The default is to have your music in your home directory.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you Eric. I have done what you suggested and it brought up a question: “Would you like iTunes to move and rename the files in your new iTunes media folder to match the “Keep it keep iTunes media folder organized“ preference?”
Before I answer yes or no what do you recommend?
さんによる
I would first make a backup (just in case!) Then say yes.
さんによる
コメントを追加
回答を追加する
Andy Walker さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 103
