メインコンテンツにスキップ
Appleの2世代目のiPad AirでWi-Fiモデルのみを対象をしています。モデル番号はA1566です。
214回答 すべてを表示
Is it possible to access data from iPad without a battery in it?
Basically, I thought the iPad that I was experimenting on was useless. now apparently I forgot to get the data off the device, while I was experimenting with the device I
  1. Damaged the connection from the battery to the motherboard. It’s probably likely that this is unrepairable
  2. I peeled up the connection between the charging port ribbon and the motherboard, I’m not entirely sure if I can get this fixed. But there are places nearby me that can do microsoldering, and I know where I can get parts for the charging ribbon cable itself.
Are any of these repairable and does the device have any hope? Any help would be appreciated, Thanks in advance
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Somehow or another you need to get power to your iPad's logic board and you will also need a means to retrieve the data via USB or WiFi.
さんによる
コメントを追加
2件の回答
ベストアンサー
Power and ground pads are easy to fix, they are literally all over the board.
Battery controller pads are more difficult and if you don’t connect them to a real battery, the device restarts every minute.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
You likely broke the pads when peeling off charging port ribbon cable from logic board, which I don’t believe is repairable.
How did you damage the connection between battery and motherboard? If board is still intact, try a new battery and see if it can power on.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
lrh33702 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 190
