メインコンテンツにスキップ
2011年10月24日発売 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405回答 すべてを表示
MacBook Pro late 2011, suddenly doesn’t boot.
Problem is:
When I press power button  I hear usual starting clicking noise and the sleep light lit for 1 second, and the screen stay blank.
What I did…
  Remove second bank of RAM, Exchange Ram Stick, and Replace RAM.
  Remove Hard Disk (SSD)
  Remove all external wire connection to computer (USB, LAN, Charger …)
  Clean with compress air CPU Fans (Was clean)
  (Battery is fully charged)
There is one time the screen Password Reset Screen appears, in upper left menu, I choose to reboot.
 Thanks for your help and advise.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント:
What happened before it stopped working? Does the system make any sound?
What does the onboard battery tester show 4 LED's or better and all steady or are they blinking?
さんによる
When I press power button I hear starting clicking noise and the sleep light lit for 1 second, and the screen stay blank.
(Battery is fully charged 8 LED steady)
さんによる
Did you have a liquid spill at some point?
さんによる
No Dan, apparently there is no reasons was working fine all over these years could be the motherboard failure ??
さんによる
While I didn't want this either, it was a lot better than what I feared.
Sorry, the 2011 systems have a known issue with the GPU chip.
さんによる
コメントを追加
1 件の回答
At this point I’m suspecting your GPU has given up the ghost. You’ll need a new logic board to fix this. I would recommend finding a 2012 system on Amazon or eBay which still has a working logic board and use it in your system.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
thanks a lot
さんによる
コメントを追加
回答を追加する
Ticla さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 89
