メインコンテンツにスキップ
2008年10月発売。2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duoプロセッサ。
376回答 すべてを表示
Why is the Nvidia 9600M GT not detected on my mb pro?
Hi,
I have two A1286 models, on the first one, I can see both, are there several models A1286 with different configuration or is my chipset dead?
I can’t see the Nvidia 9600M GT GPU in the system report, only 9400,
Thanks,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The version of MacOS likely is an issue on where you see it and don’t. The About This Mac in some versions won’t show the dedicated GPU only the Intel intergraded graphics engine. Going to the System report will show both under the Graphics/Displays heading as an example in my 2012 A1286 15” MacBook Pro:
Now some models did not offer a dedicated GPU option so you’ll only see the intergraded graphics engine within the Intel CPU. As you didn’t tell us your exact systems I can only surmise you have one of these. A good way to see what the systems specs is to plug in your systems S/N here EveryMac - Lookup to double check.
If you still see something odd take a screenshot of the listing like I did so we can see what you see iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
my mbp are both two late 2008 15” ,
The About This Mac shows Nvidia 9400 , on one model the system report shows both 9400 and 9600M gt on the other one 9400 only …i will check with serial number on every mac ,
thanks ,
さんによる
コメントを追加
回答を追加する
jmg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 103
