iPhone X - Turns off after 2 mins but NOT on lock screen-not autolock
I recently performed a replacement of an iPhone X LCD + Rear Frame Assembly. The device maintains power when turned on. However, once you enter the devices passcode it will turn off within 1-2 minutes. Autolock is set to 5 minutes. It is definitely charging. Kind of at a loss. I did confirm that it will stay on as long as you dont enter the passcode. I tested this by entering code accessing OS, pushing the power button, pushing it again and waiting on the lock screen for it to turn off. FaceID is working.
Did you transfer everything from the old housing to the replacement one? Also did you transfer the front camera over as well. The iPhone x doesn’t like parts with the wrong serial numbers.
Chris Stables さんによる
Im going to retry with all the original flexs and update this once done, the frame came preassembled. Iv done one X before (no issues with preassembled parts) but this time used a different vendor. I disconnected all the flex cables from the device one by one until I was down to two LCD connecters, battery and chargeport connecter. So Im thinking its either board or chargeport or something attached to the assembly there. Wish me luck...
Tim Collins さんによる
