I change the battery but now it doesn’t work the touch screen
After replace the battery the screen touch doesn’t work how can i fix it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The problem will be your touch connector. Make sure it is seated properly if it is I would check the connectors with a magnifying glass. I don’t suppose you have another screen to test?
このアンサーは役に立ちましたか?
Probably knocked some components off the board around the connectors. Look under magnification for any missing caps etc.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 41
