メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone reboot loop problem
I have an iPhone 6 that has a reboot loop. I tried to restore it and got error 9 so I replaced the charge port and still got error 9. I then heated up the board with my hot air station and tried the restore again and it succeeded but once the board cooled down it rebooted and started the loop again. Could it be the TriStar ic or is the nand bad?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
That is the easy way to find that shows error 9.
1- From Nand that can be solved by removing and reprogramming by programmer
2- Loose contact between CPU & RAM.
you tell that phone working after heat up board is that the problem from CPU to SDRAM loose connection that is the mistake of apple design in 6 & 6plus series phones that the error 9 cause.Such problem i solved many by this way but you have to understand that is slightly hard. you need micro soldering repair skills and instruction on it.
The I2C line have broken cause that problem .
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Robert さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 62
