メインコンテンツにスキップ
2018年9月21日に発売されたAppleの第4世代スマートウォッチ、オプションでセルラー機能付きApple Watch用ガイドです。
125回答 すべてを表示
Is there a way to replace the screen without sacrificing Apple Pay?
Per the item description for the replacement screens on this site’s store, there is a note at the bottom that says:
“When replacing the screen with a different part, it disables the NFC antenna, used for things like Apple Pay. There appears to be no easy fix for this right now. “
If I am reading this correctly, it means it is impossible to replace the Series 4 screen without loosing the functions of your NFC antenna. In other words, to replace a broken screen yourself you will trade one broken thing for another - which is obviously silly. I suppose there is a chance I am reading this incorrectly though - and my fingers are crossed that this is the case (especially after seeing the price of repair from the Apple Store).
Have any of you replaced the screen on a Series 4 and verified whether or not Apple Pay functionality is lost?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
Nope. This is like the home button on the iPhones; Apple puts in a hardware lock as a “security measure” (which, conveniently, only Apple can circumvent). If you want the screen replaced AND retain NFC functionality, you must pray at the Altar of Fruit.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
You can transfer your original NFC chip to the new one. This isn’t like the home button in the iPhone...
さんによる
Are there any tutorials for that?
さんによる
Excuse me How to transfer NFC chip to the new screen?
さんによる
@Tommy Hare is correct. You're not beholden to Apple, you just need the right tools.
If you don't have the skillset, almost every major city has at least 1 shop that specializes in micro-soldering and board level repair so the urban streetwear, "we buy gold chains and used grillz", Moneygram gangsta repair shop and cash advance loans store is out of the question.
さんによる
コメントを追加
Yes, you would need to replace swap the original NFC chip with the new screen. Use the QianLi 3D Opening Pry Tool (thin enough not to damage the cable) to lift up the lcd connector. Do the same with the digitizer connector. Once that is done, use the pry tool to remove the nfc chip (can be done with LCD separator wire )
VERY RISKY REPAIR - can damage the screen extremely easily
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brett Lyon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 39
今までの合計 4,469
