メインコンテンツにスキップ
初代Mac ProはIntel Xeonをベースにしたワークステーションコンピューターです。初代モデルには2006年から2008年のデバイスも含まれます。
317回答 すべてを表示
How do I install airport card in Mac Pro 2006?
The illustrated installation airport is nice but not for the Mac Pro First Generation. I need to know which card (I have several) to use and how to install it inside the Mac Pro 2006 1,1 (OSX 10.7.5, 32GB Ram, 2 500GB HD’s, 2 750GB HD’s) I upgraded the CPU’s from the original dual dual processors (4 cores) to the Dual Quad Processors (8 cores) it works fine but unable to flash it to 2,1. See “Flash Firmware From MacPro1,1 to MacPro2,1 OSX 10.7
So It would be nice to see a guide for the installation of the airport card for the First Generation Mac Pro’s.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The best thing is to locate the Mac Pro Service Source manual which is floating out on the internet, as we don’t have a guide to install it
Here’s the needed part: Mac Pro, Intel iMac, ATV1 Airport card (2006) But this card only supports the older 802.11n WiFi standard.
Frankly, I would recommend you just use an external Ethernet WiFi hub so you can get a faster connection and full security (WAP).
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I did find some service manuals but nothing shows a "how-to" it assumes the tech already knows how... The part numbering is good thank you. I found a few on eBay (pretty cheap too) You made part of the answer! Now for some instructions on "How-to-Install" them.
さんによる
Locate the connector on the logic board and just plug it in. You'll also need the antenna unit if its not present. Some very early systems don't offer the connector so if you have one of these theres nothing you can do internally.
さんによる
コメントを追加
回答を追加する
Michael Inman さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 322
