Memory replacement for MacBook Air 13" Early 2015
Is it possible to do memory replacement for this MBA? If so, where can I buy the memory?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sorry the RAM is soldered in this system, the SSD storage is replaceable!
このアンサーは役に立ちましたか?
Since they are not making these MacBooks thinner they needed to take out the removable dims for the ram since it takes up more space. So as Dan said sadly you will not be able to replace the RAM without a soldering station and experience with de-balling.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 3
過去 30 日: 10
今までの合計 649
