Display hinge broke from base
Hi,
My laptop hit the floor and the post that the laptop base hex screw attaches to snapped off. Not a problem, however the laptop keeps separating every time I close the lid and I have to push the top and bottom together to put the laptop to sleep. It’s now causing more internal damage and when I open it up, the clip has snapped off the laptop base as well as the screw hole to the base is also cracked in half. I’ve attached pics but wanted to know the hinge was attached to that I need to replace, as well as the hinge itself. This is on the same side as the power button. Any info would be very much appreciated. And not sure if the pictures uploaded or not but have those too.
Thanks!
Update (04/09/2019)
この質問は役に立ちましたか?
3 件のコメント
Hi,
I have a XPS 15 9550 with a broken hinge. I tried to remove the antenna cover but it is really hard and I am unable to slide it. how can I remove the cover so I can access the hinges?
Thanks for your help.
Venkat
Venkat Annangi さんによる
I bought a new chassis from eBay and swapped it all over.
I tried using liquid metal glue but it didn't hold so just bought a replacement chassis for £40
Tony Brandt さんによる
Replacement chasis? From where? Link please.
Biswanath Chakrabarty さんによる
