iPad home button not working and not charing properly
iPad 2 A1395. I replaced the digitizer and the new digitizer works fine. But I found the following two problems:
- Home button stopped working no matter how hard I try;
- iPad is not charging properly. When plug in the cable there is no charging icon. However, after a while I can see the battery percentage ramps up, but very slowly, like 2% - 5% per hour when the iPad is on. If iPad is off and I plugged the cable the iPad would turn on as expected, but there is still no charging icon.
I did broke the wifi antenna when trying to pry open the digitizer - the part close to the screws are torn off. But wifi still works so I guess that should be OK?
Could it be a bad docking/charging connector? The connector does affect the home button as well, right (since there are two connection points)? Or can it be a bad connection cable of the digitizer?
Thank you for the help in advance.
この質問は役に立ちましたか?
